Anyone here know much about 24v systems and the gauges/sending units used? Specifically, this is for an ex-MoD FFR.
I can't get the fuel gauge/sender to read and I've already ran out of fuel twice.
1. I've taken the sender out. It was totally gummed up and wouldn't even move. Got it all cleaned and lubed and it moves freely now.
2. The gauge reads slightly below E when off. When I put the key in and turn it to the "on" position the needle will instantly shoot up to level with E. It doesn't read any higher than and as long as the key is "on" it stays exactly at E. Key "off", it drops back down to just below E.
Is the sending unit 24v? If so, I would assume that the gauge is also 24v, as opposed to the civvy models running off the regulator at 10-ish volts.
Thanks for any info you can share...
Jen
Jen
