New Goodies / Showin' off
  • Daurie
    • Nov 2007
    • 251
    Here's a picture of Ikes fantastic work. I came home to find it on my porch yesterday afternoon. Today I got crackin' early and here is the result. Warn 8274 for a steal off ebay, Viking 3/8" from Winchline.com and the bumper. All in all took about an hour and a half to install. Perfect fit. Thanks Ike! (sorry the pic is so big) PS I know the RH top bolt isn't grade 8. Lowes didn't have a 7/16 square nut. As soon as I take off the rad muff I'll pull of that bracket on the bottom of the rad panel.
    '73 SIII 88"
    Turner 8:1 Engine
    NRP Exhaust
    Roverdrive
    RM Parabolics
    OME Shocks
    Warn 8274
    Pangolin4X4 bumper
  • telwyn
    • Nov 2008
    • 30
    Wow - that's nice! You'll have to change your avatar now.
    telwyn
    1982 Land Rover Lightweight
    1999 Land Rover Discovery II
    1967 m416 trailer
    • luckyjoe
      • 335
      Daurie,
      Looks really good! Was there much effect on ride height with the bumper + winch? Are you running Para's?
      Oh, and what tires are those?
      Regards,
      Tom P.
      1965 exMoD 109
      1995 RRC LWB w/EAS
        • 400
        Excellent! I have an identical winch and bumper coming from Ike, and I like the look. I am considering going to synthetic line, please let me know what you think of the Winchline.com stuff.
        I had planned to put the winch and bumper on the wife's 109, but it will likely go on mine instead. I will need another one, I guess....
        • Daurie
          • Nov 2007
          • 251
          Yeah I though about my avatar too! Definately needs an update. As far as ride height I'm gonna say ever so slightly lower. I have Rockt Mt. paras 2 leaf front 3 leaf rear. Rides a little high in the back but when I have on the hard top it levels out.
          I have yet to use any synthetic winchline. This is my first. I saw the Viking line in Overland journal and those guys know their stuff. I don't believe they would advertize anything that was sub-par. All I can say is do your research. There are some places selling synthetic line advertized as simply Amsteel. You wan Amsteel-Blue. Both can be blue in color so don't be fooled. I also like that the viking came with a chaf guard and the optional "safety thimble" on the end.
          The tires are BFG Mud Terrain KM-2 235/75-16. They have been great so far. Last time I got off in some deep stuff they pulled me right through.
          I also spent half of that particular day recovering Disco's with lesser tires.
          I can't say enough about the bumper. The fit was right on and the recessed fairlead is really trick. Very clean.
          '73 SIII 88"
          Turner 8:1 Engine
          NRP Exhaust
          Roverdrive
          RM Parabolics
          OME Shocks
          Warn 8274
          Pangolin4X4 bumper
          • CliftonRover
            • Mar 2007
            • 351
            very nice, I have seen those tires take trucks places never before thought possible...ok a bit much but they are great, and much quieter than the old bfg mt's.
            • Bertha
              • Nov 2007
              • 384
              Looks really nice, However, too bad you lost your crank hole. Does Ike build the bumper/winch mount higher so that the crank hole can be retained? It is very handy to have that ability.
              1971 88 (restored and as new)
              1967 88 (the next project)
              • leafsprung
                • 1008
                Bumper
                Looking good Daurie! Glad you like it.
                Bertha,
                I make them to order. So I can put the mount in any position. You can retain the crank hole if you wish. Even with the mount pictured you can slide the crank through the fairlead with some of the rope unspooled and engage the crank in a pinch. As with any feature its a trade off. The best place to mount a winch is between the frame rails, so that during recovery you are pulling inline with the frame. The higher you mount the winch the more stress you place on the mountings and in turn the frame.
                • badvibes
                  • Mar 2007
                  • 364
                  Sweet looking bumper/winch set-up. One question, why a hawse instead of a roller fairlead? I only have experience with steel cable and rollers, does synthetic rope work better with a hawse?
                  Jeff
                  1991 Range Rover Hunter
                  • Leslie
                    • 613
                    Jeff,
                    Good question. With steel, rollers reduce friction. But, over time, the rollers will still get burred. So, you really need to get a new fairlead if you're going to be replacing a steel line with a synthetic, so the burs won't cut the rope.
                    One thing that can happen, is that the rope can get pulled over into the corner where the fairlead rollers are, and get pinched. So, when the synthetic lines started coming out, a lot of people went with a hawse to avoid that problem.
                    Some places have come out with replacement rollers for the fairlead, that are synthetic, that are gentler on the line than steel rollers. In the current RN News, Bill Burke had a comment regarding the issue with the line getting pinched in the rollers: he would just stuff a glove in the corner, which would prevent the line from getting pulled into that pinch-point. Also, as he pointed out, most pulls 'shouldn't' pull the line over where it would get caught.
                    -L
                    '72 SIII SW 88"
                    '60 SII 88" RHD
                    • Leslie
                      • 613
                      Oh, to finish the thought.....
                      Yeah, a roller fairlead with synthetic rollers would be 'best', with and adjustment of technique to prevent it from pinching into the corner. But, a roller fairlead isn't cheap, nor are the synthetic rollers.... an aluminum hawse, that won't pinch the line, is a less expensive route if you don't have a roller fairlead. But, if you're buying a new winch, it'd probably come with one, so, it shouldn't be that big of a deal....
                      In my case, I've got a Koenig winch that didn't have a fairlead, and I've got a synthetic line for it, so, I used an aluminum hawse for it.... but, if money wasn't an issue, a new roller fairlead with synthetic rollers would be the cat's meow....
                      -L
                      '72 SIII SW 88"
                      '60 SII 88" RHD
                      • leafsprung
                        • 1008
                        Hawse fairleads are also tougher, lighter, they have no moving parts to damage and bind, and are less inexpensive to replace. I went through three roller fairleads on the front of my series one before I started using hawse fairleads. The original hawse I installed is still there. I use UHMW fairleads with rope. There can be no burs to cut the rope with this type of fairlead. Even the aluminum ones need to be inspected carefully for burrs that might easily cut the rope.
                        • pvkd
                          • 118
                          Really nice picture. The truck and Ike's work looks great! I am planning on one of his bumpers for my 109 when I get the cash together.
                          But living in Southern California - have you converted the 2.25 to battery power or something?
                          1971 109 Safari Wagon (1 ton chassis)
                          1995 LWB Range Rover Classic
                          1997 Defender 90 (repaired at last)
                          2001 P38A Range Rover
                          • Blueboy
                            • 153
                            looks great!!!
                            I've used rope now for about 7 years now and would not go back to wire.
                            Place I bought mine is: http://www.rockstomper.com/catalog/recovery/ropes.htm
                            I've also bought the al. hawse from them although after reading Bill's article in the latest RN News, maybe I didn't need to.
                            In any case, it is great stuff and just so easy/safe to use.
                            Of course you always have to be careful when winching.
                            Jaime
                            One Life Live It
