Okay I need some help here. Here's the back story. I have a 1962 IIA SWB with a Zenith carb. For one reason or another the truck sat untouched for 2 months, but I've recently calculated I last put fuel in the tank 6 months ago, so it was rather old and varnished. Tank & lines drained, fresh fuel added. The fuel pump wouldn't pump. Pump replaced. Truck would then start and run but die out (as in starving for gas) after about 20 seconds. After about a minute, it would start up again and run for another 20 seconds. I pulled the carb off and went through it. It wasn't horrible, some dust/dirt/debris but the worst thing that I found was the large O-ring at the throat of the carb to be rotten. After reassembly the truck will now start and idle happily for however long I want it to, but as soon as I move in any direction and take my foot off of the gas, it refuses to return to idle and instead stalls. It will restart (sometimes with difficulty) and again idle happily. Until I move it. I suspect that there is something amiss with the fuel mixture screw (the idle control screw) since turning it appears to make no difference. If I take out the scew completely the truck will continue to idle for a while before eventually shutting down. I can feel a vacuum being pulled through the passage. I've looked at a spare zenith carb that I have (that also needs rebuilding) and the idle control screw just appears to open/close and air passage into the carb throat, which is not clogged on my carb. Oddly my screw has a channel cut into its threads, and that channels appears to be filled with with something intentionally. The spare carbs idle control screw does not have this channel, but it is also a different size/thread pitch. Could I have my idle too high (via throttle stop screw) to allow the mixture screw to have an effect or......
The truck seems VERY cold natured...even after idling for 15 minutes, it'll bog on throttle input unless the choke is feathered on.
