Rover Plates Lifted
  • redrover
    • 6
    Rover Plates Lifted
    Hello All-
    Went out this morning to run the rover and I noticed that someone stole my orginal plates it came over with. I do not lock it and they were behind my seat. Does anyone know where I could have them replaced..( stamped etc. )
    Richard-
    Richard
    '72 SIII 109 RHD 2.5 Diesel
  • Leslie
    • 613
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    • redrover
      • 6
      Okay-
      That will work. Did not think to look to our hosts site..
      Richard-
      Richard
      • Andrew IIA
        • Feb 2008
        • 327
        This outfit may work for you also. Aluminum plates.
        Best regards, Andrew
        63 SIIA 88
        Andrew
        '63 SIIA 88" SW
          Originally posted by Andrew IIA
          That's a great site--You can get customized old license plates to match your year of manufacture. Makes me wish I had $70 to squander. Heck, that's more than I paid for my real registration and plates, but still, VERY COOL.
          • thixon
            • 909
            Man it hacks me off to hear someone did that. I was planning on adding a set from my first truck to the one I'm building. I may rivet them on after hearing this story. At least they'd have to have a drill
            Travis
            '66 IIa 88
            • greenmeanie
              • 1358
              Cheap plates, sharp edges, loosing their fingertips discourages light fingers.
                Originally posted by thixon
                ..I was planning on adding a set from my first truck to the one I'm building. I may rivet them on after hearing this story....
                I'm very hesitant to type this, but I've had my UK plates on for the full 5 years that I've owned this particular Rover, and 2 of those years I lived in a place where everything not chained down or welded gets stolen. I've had no trouble with my plates. The front one is just held on with plastic screws and nuts. The rear was glued to the rear body by the previous UK owner.
                Obviously, your results may vary...
                • redrover
                  • 6
                  Andrew IIA
                  This is what I had in mind..Cool site.. My plates were off due to some front and tail work I was doing last fall and I did not put them back on.
                  Thanks for everyones imput
                  Richard
                  • thixon
                    • 909
                    Mark,
                    Knock the daylights out of some wood....now.
                    Travis
                    '66 IIa 88
                      Mark, Knock the daylights out of some wood....now.
                      HEY--What happened to my plates????
                      • Paul Rossmann
                        • Dec 2007
                        • 76
                        Also...
                        europeanplates.com
