Stranded...Help!
I replaced battery and battery cables this past weekend in my IIA. After doing that, she would not start and none of the instruments would even turn on. Battery test said the battery was fine.
I sprayed some electrical component cleaner on the the starter switch lead (the screw that accepts the positive terminal), reconnected the positive battery cable, and she started.
This morning, as I was leaving an early morning meeting, the same thing...no instruments, no juice at all.
Assuming the battery is good, any thoughts on the problem??
Thanks!
Thanks!
