Those snow banks in parking lots can be deadly. I got stuck on one about three feet from the edge and I tried to rock it back and forth. When i put in reverse it made a loud BANG and popped out of gear. Once i got pulled out of the snow reverse did not work any more. I let the clutch out and i hear a snap crackles and pops and it jumps out of gear, but no reverse movement.
All of the other gears work fine 1-4 and the truck is a 72 series III 88. When I drain the Transmission oil later I'll take pictures of what comes out of the oil. Any ideas what I broke and what I have to do to fix it?
. Yes, the floors and seatbox need to come out. If you have a Series III, the center crossmember should be removable rather than welded on. You can lift the car and drop the transmission, or lift the transmission out of the car.
