Extract from a posting on the web "The only way to properly set up ignition points is with a dwell meter."
So when setting the points on a 2.25 petrol do you try for the gap setting recommended by Land Rover or go for the dwell regardless of the gap measurement?
Also I have been using 57 degrees - what do you use?
However when I use 57 degrees I measure the gap at 0.012" versus Land Rover recommended at 0.015" is this OK?
Paul
Paul
