Guess Saturday was the day for fuel problems, mine died also. After manually worrking the fuel pump I got it going again and it ran fine back home. Turns out the fuel line from the tank to the pump was falling apart and not only "bleeding" bits of rubber into the system but also sucking in air! Another new in-line filter, clean out the sediment bowl and I'm go until.....
Stranded on Day 2
Originally posted by greenmeanieWhat thread is on the fuel fitting. I bet you could retap it with a standard NPT tap and hose barb available from any loca hardware store.
Let me look for a picture of what I am talking about... I'll post it in a second.2005 LR3
1965 RHD Series IIA currently aka "The hope crusher"Comment
Here is a picture with a red box around the threads I am talking about... where the fuel inlet "fitting" goes into the carb.2005 LR3
You may have to lose the banjo fitting and the hard plasdtic fuel line but by the eyeball gauge you should be able to tap that with a 1/4 NPT and use a male NPT to hose barb fitting. It'll be cheaper than a new carb.Comment
Originally posted by greenmeanieYou may have to lose the banjo fitting and the hard plasdtic fuel line but by the eyeball gauge you should be able to tap that with a 1/4 NPT and use a male NPT to hose barb fitting. It'll be cheaper than a new carb.2005 LR3
Originally posted by scottdoc i've got half a dozen of those carbs. might be able to hook you up. i use a weber 32/36 dgv and will never be mess'n with em.2005 LR3
OK... so I basically need to decide if I want to keep the Solex or jump to something else.
It would seem that the Solex carb has part availability problems, other than scrounging up used ones sitting in peoples garages/sheds/basements. But it seems to work as good as any other carb as long as you keep it clean, and I already have one.
The weber is new, but has a hefty price tag since I have to buy the inexplicably expensive adapter block to put underneath it. But on the other hand I was going to replace the carb eventually anyway as part of my restoration. So instead of doing it later I am doing it sooner.
The third option, which I am not really considering, is the Zenith. Even though they were stock it seems like people have problems with them. With the Weber available, it just doesn't seem like a smart choice.
Does that sound about right to everyone? Am I missing some big piece of the puzzle here?2005 LR3
i like the weber 2brl. some say it doesn't work well on the 2.25 but my only problem has been vapor lock which i'm addressing with a carter electric pump, a fuel return line and a remotely located air filter. when running my truck hauls bauls compared to my budy's with his rochester single brl.
the adapter and carb are one time exspences, which i got lucky and didn't have cuz my truck came with the weber.
webers 2brls have been used by auto manufacters and modifiers on just about every make and model. i feel it been test and has passed.'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
You are forgetting the rochester carb
'72 S3 88 - Leakey & SqueakyComment
I've got to put a pitch in for the single barrel Weber. One of my II-A's came with the Weber at 111,000 miles. The car now has over 500,000 miles on it. In that time and 18 years of ownership, I've used a Weber carb exclusively.
In that mileage, I've changed out the carb twice and completed one repair - an accelerator pump. The carb that was swapped out was actually good enough to keep as a "spare."
The Weber can be a little lean if you're not careful with the timing and idle mixture, and I find that dry gas helps in winter because of occasional icing - but that's it. I can't remember the last time I had to adjust anything on it, and it's easy to access the filter.
My other II-A has its original Solex, which does seem to have a lot more rubber bits in it that require occasional replacement. The Solex seems to give that Rover more acceleration, but it does not achieve as good mileage as the one with the Weber. Solex gasket kits are still available, but when I broke a metal part, I had to dig out an old Solex to find the part.
The Zenith is an adequate replacement carb [there are plenty out there on a lot of Rovers] but I am a huge fan of the Weber and I recommend it highly.
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
Well, I decided to go with the 32/36 DGV for now... we will see what happens. Should be here sometime this week along with the adapter block. If it doesn't work out, I will look at getting a single barrel Weber.2005 LR3
