FC II-A or II-B Owners - Help for a Friend
  • Jeff Aronson
    Moderator
    • 569
    #16
    Ivar,
    I'm cutting and pasting your message and will email it to him. Apparently there's some issue with registration without an engine number.
    Jeff
    Jeff Aronson
    Vinalhaven, ME 04863
    '66 Series II-A SW 88"
    '66 Series II-A HT 88"
    '80 Triumph TR-7 Spider
    '80 Triumph Spitfire
    '66 Corvair Monza Coupe
    • Marc-SA
      • Mar 2009
      • 1
      #17
      Hi there Jeff,
      Get your friend to e-mail me directly on rademaker.marc@gmail.com. Where is he in South Africa as I am in Johannesburg. He will not be able to register the vehicle without the engine number. As my Ivar, my brother, let you know, I have a specialist Land Rover workshop and own a Forward Control myself, so if I can be of help, it will be a pleasure.
      Marc.
      • msggunny
        • Jan 2007
        • 621
        #18
        Its a few days late and a few Rand short but here is what i got from Landy on Line
        Richard,
        The number is usually stamped (not very deep or clearly) on the engine block forward of the exhaust manifold on a slanted face pointing towards the exhaust manifold side of the engine.
        I will have a look at an engine at home to confirm.
        Regards
        Brian
        If his engine is anything close to what mine looked like after i had it painted in Zimbabwe he will most likely need to scrape the paint off to see the engine numbers.
        04 DII
        08 D3 (LR3)
        • msggunny
          • Jan 2007
          • 621
          #19
          FYI, the guys at Landy On Line sent this, confirming the placement of the engine numbers:
          CONFIRMED - in front of #1 exhaust port on the block.
          04 DII
          08 D3 (LR3)
