Deluxe Highback Seats
  • bronsonarlo
    • Mar 2008
    • 29
    Does anyone know where I can find a pair of these Deluxe Highbacks
  • Jim-ME
    • 1379
    I thought that our host sold them but I can't seem to find where. Atlantic British shows them but says check on availability. British Pacific shows just the high backs for sale. You might want to consider looking for used Defender seats as an alternative.
    Jim
    • Erik B
      RN Sales Team
      • May 2006
      • 11
      Good morning, just give us a call, and we can go over the different options available to you.
      • ybt502r
        • Oct 2007
        • 81
        Side question - where did you get the nice formed door panels? I've got the basic SIII panel (vinyl covered cardboard) in which I've cut and mounted some speakers. Nice and functional, but yours actually look designed for the door.
        77 88" SIII County SW
        82 Jp CJ8
        • Leslie
          • 613
          Those look like the panels carried by our hosts.
          -L
          '72 SIII SW 88"
          '60 SII 88" RHD
          • Eric W S
            • 609
            That looks like a pic from ECR, if so they were the older Defender models that were modified to fit the series. I think that is the pic of the coil sprung 88 with the 2.5 Diesel and D-90 style cage...
            EwS
            http://www.eastcoastrover.com/87gallery.html I thought I recognized Mike's work...
            • leafsprung
              • 1008
              Those are not 90 seats . . .
              • Leslie
                • 613
                Are we still off topic on the panels, or are you referring to the seats?
                Panels:
                Seats:
                Look like a too-thin aftermarket SIII seat w/ a headrest.
                -L
                '72 SIII SW 88"
                '60 SII 88" RHD
                • Andrew IIA
                  • Feb 2008
                  • 327
                  Panels:
                  Seats:
                  What makes those door panels (which I think look good) SIII/D90 specific ? is it just the anti-burst latches ? (which are fitted to my SIIA, which is why I'm curious)
                  Regards, Andrew
                  Andrew
                  '63 SIIA 88" SW
                  • Leslie
                    • 613
                    That'd be part of it. Another problem might be the door limiter.
                    I have LaSalle panels on mine, and have a problem where the elbow of the limiting arm, upon closing the door, presses outward on the panel. SIIa's use the plunger-tube type instead, I don't see how it wouldn't be compatible, but it could take some fiddling... don't know, haven't tried....
                    -L
                    '72 SIII SW 88"
                    '60 SII 88" RHD
                    • Blueboy
                      • 153
                      Seats:
                      Blueboy has the same seats and they are pretty comfortable.
                      by the way, Happy Birthday Leslie.
                      Jaime
                      One Life Live It
                      • Eric W S
                        • 609
                        Panels:
                        Seats:
                        No. The Door Panels were according to Mike in the description of the build Defender panels modified to fit.
                        Those panels linked above were not even available when that truck was built. Mike had a thread on D-90.com about the panels and the input he gave RN.
                        I know what Defender seats are. I had a 97 Defender for 10 years. Where are you guys getting seats from?
                        • Eric W S
                          • 609
                          Regards, Andrew
                          Well aside from the fact that the original Defener Panels are NLA, Defenders had a provision for a speaker, wiring to the speaker, and depending on the MY, a map pocket of different sorts. Also SW had a providion for a window handle and the door locks on top.
                          ST were similar.
                          • luckyjoe
                            • 335
                            Those seats were a LR option - p/n MRC6981 hiback Deluxe seatbacks.
                            Tom P.
                            Tom P.
                            1965 exMoD 109
                            1995 RRC LWB w/EAS
                            • thixon
                              • 909
                              I had a set of those seats in my old SIII. The only complaint I had was with the head rests. They were attached to the seatbacks by way of two metal posts that inserted into the body of the seat back, which was just vinyl covered foam. No big surprise there, but during an off roading session, I noticed an uncomfortable issue. I dropped down a creek bed, which caused me to bang my head against the head rest. When I did, the two metal posts bucked forward inside the seat back, and bruised the daylights out of my back just under my shoulder blades. The problem is that there is no support structure inside the seat to brace the metal posts (the posts are just inserted into holes in the foam). I always used to worry about what would happen if I ever got rear ended.
                              Travis
                              '66 IIa 88
