I am about to install a cd player and speakers in my 2a 88 and i do not want to buy a center tuffy box or get rid of my third front seat. Has anyone found a clean place to mount a standard CD Deck. Also does crutchfield sell those surrounds to mount on the underside of a dash, or seat box?
Radio Head unit in a series
Make sure you get good speakers and a powerful amp so you can hear it1958 107 SW - Sold to a better home
You might be able to adapt the factory Defender radio head unit mount.
http://www.roversnorth.com/store/p-2939-radio-housing-defender-.aspxComment
For a IIa, I'd suggest looking at Thompson's link above. In my III, there's a spot where I did cut a square little hole for the front of the deck to stick out, and used a kit from Crutchfield to install it. Lemme see if I can find a pic..... BRB....-L
'72 SIII SW 88"
'60 SII 88" RHDComment
In a SIII, there's a spot on the dash that has some holes in the steel, covered by foam.... the radio is a Kenwood w/ 25w into 2 channels, I've got a pair of Polk 6" marine speakers in my doors. For a SIIa, again, I like the idea of using the Defender shelf mount.... haven't tried it, the SII had the radio mounted overhead already.... not sure I like it there, might relocate it....
Here's my radio:-L
'72 SIII SW 88"
Local club member did this.
I have seen another truck where they used a pre-amp (I may be totally wrong as I don't know radios) with an ipod plug-in. So again, no radio but could only play an ipod.
Me personally, I just use the ipod w/headphones.74 SIII
96 Disco SE-7 5 Spd.Comment
I also did the motorcycle speakers/amp, thing.
The speakers fit perfectly on the "shelf" just behind the vents in the dash, and the only invasive thing I did, was stick a piece of velcro to the dash, so my Ipod had a place to sit during travel.
No holes, no fab-work. All music, all the time. I'm pleased with it."I can't believe I'm sitting here, completely surrounded by no beer!" -OnslowComment
Oh, I left that out.....
I installed an Audiovox FM modulator inline with the antenna. REALLY nice little unit. At the flick of a switch, it feeds your RCA input in through the radio, w/ no radio signal walking in over it the way most FM units use. I have a RCA-to-headphone adapter w/ it, so I can plug in my Zune or my Walkman.
Thing about using my Kenwood: I already had it; as a cassette deck, it looks correct in a Series; 25wx2channels; is great as a radio; w/ the FM modulator, I can play an iPod or whatever.... The Polks were the most expensive part, and only because I wanted shallow-mounting marine 3-ways of a ~6" diameter, and even they weren't that much, getting them off ebay.-L
'72 SIII SW 88"
those are very good ideas. the reason i am looking into a full stereo is that i had my ipod stolen from the seriesand i don't really want to buy another. I have an older Sony head unit and a couple bostons to put in the doors (free).
The problem about the shelf plastic box is that under the dash i have the heat duct blocking a clean spot to mount one. Crutchfield has the same thing as the defender oem but $24 not $58. I was also thinking of boat stereo housing. I could install it along the head liner.or on the plate on above the dash below the wind sheild
That motocycle unit is a great idea if i can find a good CD/Radio with Ant. I could velcro that to the top of the dash.
Any other pics/ ideas would be welcomeBrent
Wrightsville Beach, NC/ Roanoke, Va
'67 Series IIa (former Bugeye)
'86 911 Carerra 3.2
'88 BMW M5Comment
i haven't done this yet but i was also thinking of installing cd/radio. i was thinking of mounting a board across the top of the roof, this would still give you several inches to mount the radio i plan on putting my cb up there to if there is enought room and it shouldn;t interfer with visablity. you could also store clutter up thereComment
Originally posted by ClembsI am about to install a cd player and speakers in my 2a 88 and i do not want to buy a center tuffy box or get rid of my third front seat. Has anyone found a clean place to mount a standard CD Deck. Also does crutchfield sell those surrounds to mount on the underside of a dash, or seat box?1965 109 2door hardtop (restored years ago)
1971 88 (restored and as new)
1967 88 (the next project)Comment
Originally posted by BGGBi haven't done this yet but i was also thinking of installing cd/radio. i was thinking of mounting a board across the top of the roof, this would still give you several inches to mount the radio i plan on putting my cb up there to if there is enought room and it shouldn;t interfer with visablity. you could also store clutter up there-L
'72 SIII SW 88"
the other place i had been thinking of is the front of the driver's seat box vertically in the floor board. Does anyone know if Modern CD decks can play cds vertically? I think with the plastic cover from a D90 or CF would be pretty tucked in, if there is enough room for my feet.Brent
'86 911 Carerra 3.2
'88 BMW M5Comment
