Well if it's not going to be done even close to right then I vote for covering it with duct tape and squirting some undercoating over it!
Scott, this is your truck and you are going to do what you want to it. You will also have to live with it. Do you want to be visiting this same problem in a few years or do you want to be done with it for a long time so you can move on to better rover projects?
The bulkhead is important. The clutch and brake pedals mount to it, the doors mount to it, the floor boards mount to it, the door thresholds mount to it, the windshield frame mounts to it, the bonnet mounts to it, the fenders mount to it, brake lines and clutch lines might be mounted to it, electrical wiring and devices are mounted to it or run through it, the heater is probably mounted to it, the bulkhead itself is mounted directly to the frame. My unmolested, non-rusted original bulkhead flexes quite a bit under hard steering since the column and steering box mounting bracket are bolted directly to it. It's neither a spine or a pair of underwear, it is an important part of the vehicle. I guess if it were a pair of underwear you could either clean them or wear them as is, skid marks and all....
Jason T.
Jason T.
