'72 SIIA 88 with 2.25 gas engine. I drove it 130 miles today. When I got home I was backing it into the driveway, it stalled and wouldn't start. I'm pretty sure I stalled it. Since it was relatively warm today (65-70f), and I ran so long, the engine compartment was definitely heat soaked. This was also evident by the heat coming through the bulkhead. After about an hour it started right up and ran smoothly.
I had the same thing happen last year, but unfortunately not at the base of my driveway. I had previously replaced the plugs, wires, cap and rotor. This time I replace the coil, but had not run it hard and long in the heat until today.
I definitely have fuel and air, so I have to assume it is ingnition. What could be causing this? Points, condenser or timing? Could it be something with the carb? I have always noticed the Rover starts very easily when cold, even in the winter months, but on warm/hot days after being run it is takes longer to start. It is only after a long hot run that the Rover will fail to start.
Larry M.
Larry M.
