I saw a limestone 88 today. Either an siii or late iia with a soft top. I saw it from a distance, but it appeared to have a roof rack mounted with the soft top in place. Nice trick. If you're on this board, how'd you do that?
anyone here in Charleston, sc?
trav it wasn't me but i'm building a full rack for my soft top. starting with 2 2" c channel cut about 2" long. picture the c openning down, one behind the driver's seat on the bulkhead 5" from the corner. the other going on the driver's side tub rail about 5" back. next i connect these w/ some 2x1/4" flat stock running diagnally inside the tub, welded towards the bottom of the c channels and flat side parallel to the deck. go to the outside of the one on the tub rail and weld a 2" piece of 2" ankle iron such the the verticle of the angle iron is welded to the side of the c channel that's on the outside of the tub and the horizontal side sticks out perpendicular to the tub. on this "tab" i'll weld a 2" piece of pipe that has an id of 1". i'll make four of these, one for each corner of the tub. now i slide some 1" gavanized emt into the pipe so that it runs up to support the rack. then two more 1" emt with the ends squished and drilled to go on the outside of the windscreen hinges. i figure this will not interfer w/ the canvas and i could still drop the windscreen with the rack on or off.'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
'07 LR3 (Series Recovery Vehicle) -
Scott,
I want to see some photos of that when you finish it. Sounds interesting. If it works out for you, I may copy your design
Because I'm in georgia, the softop is the way to go, but I really need a way to carry a conoe, and some other stuff around.
Thanks,Travis
'66 IIa 88Comment
