Looking to end, once an for all time, my sticky Series gas pedal. Anyone have any good fixes?
Sticky Series II gas pedal - any good fixes or mods?
Where is it sticking ? All original linkage ?
Andrew,
'63 SIIA 88"Andrew
'63 SIIA 88" SW
Rover Pics: http://www.flickr.com/photos/skunkal...7610584998247/ -
In the past I have found that the bits that stick on mine are the little balljoints in the linkage and the spring return on the 'mainshaft' that is the last bit attached to the body and not the engine on the way to the carb.
Either take them apart and REALLY clean them or get a good spray lube, not WD-40 but something like silicone lubricant or breakfree (gun stores) and make spraying each joint down part of the regular maintenance. Also, make sure that the return springs are good, strong and can actually 'return' ie.. in the right place to fully return the pedal. Come to think about it, I would check your springs first and if need be add another!
There's a bushing that the accelerator pedal pivots through. Make certain you lubricate that, too.
Otherwise, have you ever replaced the return spring? If so, then I, too, second the recommendations made above.
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
D90 pedal, bracket and cable. Done. The bracket and pedal need to be modified a bit but well worth the effort. Whoever designed that pedal and linkage contraption was an evil man.Comment
Originally posted by MercedesroverD90 pedal, bracket and cable. Done. The bracket and pedal need to be modified a bit but well worth the effort. Whoever designed that pedal and linkage contraption was an evil man.1958 107 SW - Sold to a better home
Probably dates back to Sir Harrry Ferguson....Les Parker
