plastic tubing?
  • MerlynIIa
    • Sep 2007
    • 54
    plastic tubing?
    Probably a stupid question. I am taking apart my III. When I removed the seat box, I found plastic tubing that is clipped to the front of the tub just below the joint with the seat box. It extends from side to side and goes up through a rubber grommet into the void behind the driver's door striker plate on the tub, forming a loop there. the tubing it not attached to anything, but goes to the other side near where the gas tank had been (removed by Po) The tubing is similar to windshield washer tubing, black, plastic and has elbow joints to connect pieces of the tubing. The clips look factory but could be added later. It is not connected to anything. Anyone know what it is for?
    '65 Series IIa (not running)
    "73 Series III (not running)
    (combining the two to make one.)
    '00 Disco II
  • jac04
    • 1884
    Extended axle case breather maybe?
    • greenmeanie
      • 1358
      It'll be the tubing to connect the main fuel tank on the passenger side to the expansion tank that should be under the front section of the rear wing on the driver's side. I have no idea why they chose the routing. There should be another section going from the expansion tank to the charcoal cannister in the engine bay.
      • kevin-ct
        • 309
        It is a factory option, It is a pee tube for extend drives that we all take in a Series.
        Kevin
        04 XJ8
        92 RRC
        02 Benz E320
        95 RRC (sold 5/10)
        72 Series 3 (sold 4/10)
        70 Series 2A (sold 6/10)
        Morgan +8 (sold 8/09)
        90 Jetta (308k miles) (sold 5/11)
        72 Triumph Stag (sold 1/08
        • MerlynIIa
          • Sep 2007
          • 54
          I'll take a look for the charcoal canister and to give a better idea of the routing. it looked like it went back and forth from one side to the other, but may have had a disconnect near the rear drivers side wing. However, a Pee tube would be nice
          thanks for the replies
          '00 Disco II
          • crankin
            • Jul 2008
            • 696
            It goes to the expansion tank that is under the driver side.
            Birmabright Brotherhood
            Clint Rankin - 1972 SIII SWB
            • LH Drive
              • 253
              My '72 S3 also has the same black tube you mention routed the same way. It's not connected to anything but has a threaded male end hanging over the gas tank. My gas tank was replaced by the PO with a FoRover Forever stainless tank and I thought at one point the tube was connected to the original tank and served as a breather. Just a guess...
              1972 NAS Series 88 SW
              • crankin
                • Jul 2008
                • 696
                [FONT='Verdana','sans-serif']By expansion tank..I mean the little box that fits under the driver side tub. I've heard it was for emissions. Not sure. I do know that you do not need it.[/FONT]
                • acpatsouris
                  RN Sales Team
                  • Apr 2006
                  • 30
                  In case you wanted to see what was originally installed at the factory, here's a copy of the illustrated parts diagram:
                  Arthur Patsouris
                  Sales Manager
                  Rovers North Sales Team
                  • rwollschlager
                    • Sep 2007
                    • 583
                    Art,
                    are you gonna make it down for BBTS 09'???
                    -Rob
                    72 SIII 88
                    67 SIIA 109
                    82 SIII Stage 1 V8
                    • acpatsouris
                      RN Sales Team
                      • Apr 2006
                      • 30
                      I'm thinking about it. I'm hoping to have something interesting to bring down for the show.
                      Arthur Patsouris
                      Sales Manager
                        Removal of factory-installed emissions equipment an a motor vehicle is not permitted and is punishable by death (or worse) in California (and possibly Massachusetts too).
                        • MerlynIIa
                          • Sep 2007
                          • 54
                          Thanks for settling this question for me. The forum is a great help!
                          '00 Disco II
                          • Eric W S
                            • 609
                            Anyone know what year that set up began in?
                            I would think my 65 would not have that from the factory. But hey, you never know
                            • crankin
                              • Jul 2008
                              • 696
                              My '72 had a the remnants of one on it. I had to cut the bolts off and remove it....and patch the holes left behind.
                              As for the emissions removal punishments....I live in Tennessee, where we pour oil in creeks, shoot grey owls, and burn tires. Emission control is for hippies and tree huggers.
