When I hit a pothole sometimes the steering wheel attempts to wrench from my hand a go left to right back and forth numerous times with an awful shudder. The entire 109 shudders and the closest thing I can compare it to is you feel like the wheels are coming off the front end. Help appreciated before I give myself and a passenger a heart attack or worse. Seems to be sparked by a bump in the road or pothole etc.
Scary Wheel/steering
Check your wheel bearings, T.R.E's as well.... -
Check the swivel pins/railco bushings. jack the Rover up and grasp the top and bottom of the wheel and see if there is any play- "" for left and right, you might need an assistant to look at the tie rod ends etc.Comment
X2 on the swivel pinsOriginally posted by yorkerCheck the swivel pins/railco bushings. jack the Rover up and grasp the top and bottom of the wheel and see if there is any play- "" for left and right, you might need an assistant to look at the tie rod ends etc.Comment
As recommended, lift the wheels, put your hands at 12 and 6 o'clock, and rock the wheel. If you have movement, you should remove a shim in the Railco bushing. The Haynes Manual or the LR Shop Manual will tell you how - it is an easy job.
If you have a trolley jack and jack stands, get the front end up in the air and check the steering arms and tie rod ends for play. You may need to replace some of them.
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
I'd start checking the cheaper components that are easy to check and adjust/replace. The steering system is just that--a system. A tiny bit of play in several components adds up to a lot of play in the system. This is what I'd do:
Have somebody rock the steering wheel back and forth and:
1) look at the steering arm that comes out of the steering box for movement. If the steering wheel has movement but the arm doesn't, adjust the steering gearbox freeplay. Then:
2) look at the ball joints (tie rod ends) on the longitudinal steering tube that connect the arm on the steering gearbox to the arm on the steering relay in the chassis. If the arm on the gearbox moves but the arm on the relay doesn't then the rod ends on the steering tube are sloppy and worn and need replacement.
3) Look at the steering relay to make sure movement transfers smoothly and simultaneously from top to bottom. Presumably it will be smooth and simultaneous. If not, you've got your work cut out for you. Next,:
4) check for slop in the drag link and track rod ends as in #2 above and replace rod ends as required.
Finally, jack up each front wheel and check the swivel pins and wheel bearings for play.
Good Luck!--Mark
Also, make sure that the steering box itself is bolted up solid to the bracket and bulkhead. I think the other things mentioned are more likely to cause the death wobbles but a loose steering box can certainly cause excessive free play.Comment
Was not able to get much accomplished this weekend but have a question. I was looking for the nut/slotted thread where you can adjust the steering box and cannot find it. I thought it would be easy to locate but even with flashlight could not find. Do I have to remove anything for access? My Series is RHD. Thank you.Comment
I just did mine last week--Remove the steering box splash guard in the right front wheelwell. It is the little box sticking into the upper rear of the driver's side wheelwell held on with um...4, I think...bolts.Originally posted by PH4I was looking for the nut/slotted thread where you can adjust the steering box and cannot find it. I thought it would be easy to locate but even with flashlight could not find. Do I have to remove anything for access? My Series is RHD. Thank you.
The adjuster and jam nut will be right under there.--Mark
The shims just adjust the depth the kingpin sits in its bushing which adjust the preload on it and the bottom bearing. You have different sizes, .005, .010 & .030 IIRC to make up your shim pack. It makes ordering parts fun but I usually order 4, 4 & 2 respectively.
Adjusting the shims is just a matter of taking a good guess at a pack height (I think I start about .050 and end up going down every time) and assembling the kingpin, measure the preload, strip it back down, adjust the shim pack and start again. It doesn't take long to do once you get the hang of it.
To measure the prelaod you attach the fish scale hook through the eye at the end of the steering arm and pull the swivel gently through its range. Make sure you remove the swivel seal first. For more detail refer to the green bible.Comment
