So my series has the transmission, transfer case and axles from a D90 (LT77 and LT230 I imagine). Both pumpkins are leaking a bit more significant than the average leak...and yes I know all land rovers leak. Also, the ebrake drum is slingling crap everywhere ...all over the muffler causing it to burn. So obviously I'm going to need a gasket or some other item there.
1.) By looking at the pictures and seeing the setup I have, can any of you direct me to exactly what parts I would need to purchase I were to have the leaks fixed for the most part?
2.) Obviously I have tranny fluid leaking from somewhere. What would need to be done as far as replacing gaskets to prevent this leak?
3.) Is there suppose to be some type of sheet metal that prevent mud and water from slinging up off of the front drivers side wheel onto the master cylinder/steering box? If so, where can I get one of these?
PS-yes my front tie rod is bent. I'm looking for a used one to replace it.
Sorry for the nooblike questions but my rover is a hybrid so I have never known what was stock and what was modified.
