Hey i have seen forums with the 2.25 rebuild but wanted to get a fresh view of cost parts and time.
I just found out a friend is doing a rebuild this summer on a 2.25. I am buying his old 2.25 with a down 4th cylinder. I plan to rebuild that with a 2.5 cam and new seals, gaskets, bearings, paint, and dist. I might then (money ?) buy our host SIII rebuilt tranny and trans case combo. I do not plan to replace everything but I have the time, im a teacher, woohoo, and my truck is running nice but a little low on power. What are must to do with rebuilds.
I plan to port and polish the head with guides, springs, valves, and gasket.
Hone the cylinders to get compression back,
Should i get new piston heads or just soak the originals if they are good?
Bearings, rods and oil pump will be as needed.
Externals:
New Dist with me new Pertronix
Intake Manifold
Keep carb Webber
Fuel pump.
I know Turner is what everyone says but i have the time and am very precise so i think it will be a good project for the summer
I will weigh cost and maybe a turner 2.5 head will happen.
Externals:
Intake Manifold
Keep carb Webber
Fuel pump.
