Hi folks, I'm putting together a '71 IIA with the voltage stabilizer for the fuel and temp gauge. All is going well but I noticed on assembly my gauges aren't moving. (Yes, I have fuel in the tank :-) ). I took a voltmeter to the upstream side of the voltage stabilizer and got my 12 volts as expected. Downstream side is all over the map - it fluctuates hitting 0, 12, 0, 4, etc. when I was expecting to see 10V. Is this because you can't test a voltage stabilizer with a digital voltmeter???
Should I
A) Borrow an analog meter and test it (what am I looking for)
B) Skip the voltage stabilizer altogether (not likely)
C) Stop overanalyzing and drop 20 bucks on a new voltage stabilizer.
Thanks as always for the advice,
John O
Should I
John O
