Where can I find this part?
  • NC Rover
    • Dec 2007
    • 288
    The part needed is the top picture. The bottom pic shows where the small metal lip has broken away on my rover and now rattles around as the axle spins causing it to sound like my transmission is falling out. I get lots of wierd looks when I drive by since its so loud.
    thanks!
    1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
  • Les Parker
    • May 2006
    • 2020
    Hello there,
    This looks like an LT230 front drive flange.
    If this is the case :-
    1. PLD462 Drive flange Current price is $40.95 and currently in stock.
    Please advise
    Les Parker
    • Les Parker
      • May 2006
      • 2020
      Here's the link :-
      Les Parker
      • NC Rover
        • Dec 2007
        • 288
        Originally posted by Les Parker
        Hello there,
        Please advise
        I believe thats it! I will be ordering that today!
        • ktom300
          • 50
          [quote=NC Rover]The part needed is the top picture. The bottom pic shows where the small metal lip has broken away on my rover and now rattles around as the axle spins causing it to sound like my transmission is falling out. I get lots of wierd looks when I drive by since its so loud.
          thanks!
          Mine does something similar when coming to a stop below 15 mph. Clunks around like the u-joints are coming apart on the front driveline or it's out of balance. Seems to go away in 4 wheel drive and under acceleration.
          I will have to look if I have the same issue.
          • NC Rover
            • Dec 2007
            • 288
            [quote=ktom300]
            It took me forever to find the issue. I always thought it was something with the driveline. After climbing under and poking around, I accidently bumped that metal lip and it made the same jingle sound it does when driving down the road. Since the ring broke away from the orignal part, its like having a giant noisy washer hanging loose around the drive shaft. So it just spings and clanks around. Very annoying.
            • daveb
              • 513
              are you saying the mudshiled is loose? they are just supposed to be a light press fit, easy to to with a small hammer and drift. if it goes on cocked it can deform and come loose. you should be able to bend the flange back to improve the fit and maybe use some loctite to help things along
              [quote=NC Rover]
              • sven
                • 174
                Yeah I cant imagine the mudsheild making a bunch of noise. Id check the pinion for excessive freeplay. There's a bearing behind that pinion that gets all loose and causes vibes. Bearing is a 6307-J, I believe.
                99 D1
                73 Series III 88"
                95 RRC LWB
