assuming the parts are available this should be a doddle.
engine out,
remove exhaust and intake manifolds
place upside down on a spare tire
remove clutch flywheel and bellhousing
remove oil pan
check bearing clearances rods and mains using plastigauge
remove crankshaft and take to machine shop for checking
replace crankshaft and bearings
torque to spec and check clearance using plastigauge
replace oil pan
" flywheel
" clutch with new
" bellhousing
" engine
engine out,
remove oil pan
replace oil pan
" flywheel
" clutch with new
" bellhousing
" engine
