I have need of the greater knowledge of the readership - I've an 88" SIII with pretty standard mechanics. I've noticed recently a real reluctance to shift from 1-2 and sometimes from 2-3 when cold. It seems to get smoother/better when warm. As it is now actually nearing spring here in Calgary, I'm glad for that. I think the issue is with 2nd gear - getting into it and sometimes (very occasionally) staying in - it has now and then jumped out of 2nd when I let up the gas (and thus change the stress on the drivetrain).
Accompanying all this is what seems to be a "transmission thump" whereby the whole drive train seems to jump a bit (like when I put in the clutch to go from 2 to 3). I'm hard pressed to say it's shifting any worse, but after the long winter of -20C, I'm not sure I remember last summer. Something's amiss.
I am going to get underneath it and check all the fluid levels - hoping it's something as simple as that - but is there anything (engine mounts?) I need to look at while I'm at it? This is a rebuilt SIII, and I was informed that the transmission was reconditioned at the time (about 7 years ago, and it's not seen a lot of miles since then).
