Before I install the cylinder head on the block, how should I prep the surface of the cylinder block? Should I just clean it, and how, or should I sand it with fine paper?
Prepping the cylinder block surface for cylinder head install.
Do not sand it. Clean it to as near perfection as you can using your favourite potion. If you have any raised marks due to minor abuse remove them gently with a flat file. -
Awe, just bolt it on, it'll be fine.
First, protect the cylinders by covering/putting paper towels in them, or whatever tickles your fancy. Get youself a razor scraper, and use it to remove any of the big stuff left from the old gasket. Go slow, and take your time. Some people will tell you to use a putty knife. I don't because the opportunity to put a big scratch in the block surface is possible. Next, use a good solvent to really clean things up. Lacquer thinner, brake clean or something that evaporates without a film is best. I know people who are **** enough to use car polish at the end to really shine things up. I have never done this, and never will.
Using a pad, or sand paper is an option. I'd be lying if I said I'd never done it, just be aware that you could ruin the mating surface if you over did it with either, so I won't recommend it to you.
Hope this helps.Travis
'66 IIa 88Comment
I have heard that a good buff with steel wool is not a bad idea - naturally all the cylinder protection ideas stated above.
Of I used sand paper - it would have to be 400grit or something like that - and use a block or something else like that....Firemanshort
1980 Stage One
