are there any of you guys out there with an indepth undestanding of air flow dynamics?
i've a web 32/36 dgv and i've calculated the area of the barrels going into the intake manifolds. i've also have the small single snout plenum that k&n sells. the area of the snout is just a hair smaller than the area of the carb's two barrels combined. a 32/36 has 2.824 sq in of area and the snout has 2.405 sq in.
i'm using this plenum to hook to a remote air filter (snorked)
am i choking the intake to the point i'd notice lost hp? should i consider this other plenum that has a snout with an openning messuring 11.045 sq in?
which ever plenum i use i'll be sucking air down a 3" dia smooth walled pipe with a couple of gentle turns. pipe will be about 4' long. the area of a 3" openning is 7.07 sq in
and i know exhaust affects this too. i've already went to a 1 3/4" dia exhaust and a series iii exhaust manifold.
