The 11" front brakes on my SIII are just like to front brakes on the 109. They have 2 wheel cylinders at each wheel - one top and one bottom. The flex line comes into the top cylinder. A hard line then connects the top cylinder to the bottom cylinder. The bottom cylinder has a bleed screw.
Now, if I'm looking at this system correctly, how am I ever going to get the air out of the system? The inlet & outlet on the top cylinder are located at the high point of the cylinder, which is good. This means that fluid coming into the top cylinder will push out air and the fluid will eventually fill the cylinder, come out of the cylinder, and head into the bottom cylinder through the connector pipe.
However, the inlet & outlet on the bottom cylinder are at the bottom of the cylinder, meaning that air will get trapped in the bottom cylinder. Even if I try to reverse bleed (force fluid in through the bleed screw), there will always be an air pocket.
Is there a trick to bleeding these brakes? The Green Bible specifies a normal bleeding procedure.
