Best Performing Carb?
  • bronsonarlo
    • Mar 2008
    • 29
    What would be the best carb for a 9:1 head? I am looking to put a 9:1 performance head on for better power, but didn't know if I should keep my Zeinth carb.
  • NC Rover
    • Dec 2007
    • 288
    I have a Turner Engineering head with oversized intake/exhaust valves & mild grind off of the stock cam. Currently using the Weber 32/34 DMTL carb and its fantastic.
    1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
    • greenmeanie
      • 1358
      You are gaining compression with the 9:1 head but not flow. Your existing carb should be fine but may need rejetted depending on what else you've done.
      • Tim Smith
        • 1504
        The best performing carb I've ever had was the SU carb as fitted with the ACR performance package. I never idled smooth but boy did it pack a wallop... for a rover.
        It should be noted that the header was modified for the carb and there were other goodies like a twisted cam. So this may be out of your range. Check the ACR website for prices. http://www.automotivecomp.com
        Another thing to note. The above power plus kit only got about 10 miles per gallon. My Weber 34ICH with a standard set up gets around 18 if I'm good. Performance is as you'd expect
        • bobzinak
          • Apr 2009
          • 91
          carb
          I too have a acr SU carb set up with a performance plus 2.5 (2.8) My milage has always been good..If I behave when I drive. the best I've ever gotten was 310 miles from full tank to running dry..Typically between 250 and 275 miles per tank (12.5 gallons) this is a vast improvement over my old rodchester..witch was 12 to 17 mpg..Bobzinak
          • gudjeon
            • 613
            I run a bog standard rebuilt 2.25 w/7:1 head and Pertronix in the distributor and Zenith carb. I have no overdrive and I can get 24mpg on the hwy.
            • LaneRover
              • 1743
              Imperial or US?
              Also, what is your definition of highway or highway speed? :-)
              • gudjeon
                • 613
                I run around 60 mph on the highway, when topography allows of course. Just a tad under the 100km/hr posted limit here (checked with GPS) and 24mpg Imperial and 20mpg US lite gallons. I'm talking winding Canuck highway here.
                • LaneRover
                  • 1743
                  20 on US is still pretty damn good!
                  • Tim Smith
                    • 1504
                    I agree.
                    Out of curiosity gudjeon, what tires are you running?
                    • gudjeon
                      • 613
                      I run 215/85/r16 light truck radials.
