starter won't do it....I tried it two weeks ago. well......that was before letting the marvel sit. everyone else said to use the crank, get it unstuck, then crank it a few times to get some oil pressure to the valves?
They're not that expensive. I bought a new one for my second II-A from Rovers North.
Once, when my Rover would not start on the starter, I yanked on the crank to start it. Instead, the crank snapped in my hand. They don't really give that much leverage. You might want to try a breaker bar and socket on the starter dog or the crank pulley, instead.
Marvel Mystery Oil or even diesel fuel down the cylinders should help to free the pistons. If you can get it to turn, put in fresh oil before you actually try and get it to run on the ignition.
Good luck,
Jeff
Jeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe http://www.landroverwriter.com
