The LR repair manual says I should have some screws which allow removal. My 82 SIII 88" does not have any screws. Any suggestions welcome. Thanks
Brake Drum Removal
Brake Drum Removal
sigpic
Nate B
88 D90 RHD, V8 Present
80 Merc 230GE Petrol in 2011
92 Range Rover - In the 90's
There are 2 holes, one large which goes inside the drum and one smaller which has metal behind it. The larger hole should have threads which I can screw in a bolt to push off the drum ?????sigpic
Nate B
cuis2000@yahoo.comComment
Usually the screw sits in the hole that goes into the drum to help hold the brake drum on (because the tire and rim aren't quite good enough I guess). Usually you take the screw out of that and then put it in the threaded hole that has metal behind it. Do not use this to 'force' the drum out but as a way to hold it out once you have been able to get some movement.
Our hosts have those screws but any screw of the same size and the same threading will help with drum removal.
Hope this helps.
are they just being held on there by the lug nuts because I know that that is what I did because those screws are hard to get out, your brakes work fine though because the shoes could be holding them on there if they are not working properly.
Good Luck!-Ethan
1966 2a 88' Pickup
1966 2a 109' Pickup
2002 F550 7.3l
1997 f250 7.3lComment
that's what I think is happening BUT I didn't want to tap on it with a hammer unless it was true.sigpic
Nate B
The screws that help hold the drum in place are relatively wide and short. They have a slotted, flathead screwdriver top. Since they're quite short they don't do a lot of the "holding" of the drum in place. That said, they should be on there. I'm pretty certain they're a fine thread/odd size that can be harder to find.
There's a single hole, narrower than the others, that serves as a way to take a bolt that will fit and, using a wrench, tighten it such that it helps push the drum away from the shoes and the backing plate. It's a better bet than hammering it off because you won't crack an edge that way.
If you must hammer it off, go all the way around the drum and don't try to remove it from just one spot. Also, make certain your brakes adjusters are in all the way to lessen resistance.
Good luck,
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
You can Tap it with a hammer but when this happend to me I had to pry between the backing plate an the drum with a screw driver top and bottom, so that the drum comes off evenly. You can also ajust the bolt on the back of the backing plate(This moves the shoes in and out.) That could help also.-Ethan
1966 2a 88' Pickup
1966 2a 109' Pickup
2002 F550 7.3l
Brake Drum Removal
I'm in the same situation- trying to remove the brake drums. I have one flathead screw per drum, and they are stuck. My feeble attempts thus far to remove them with a wide screw driver have begun to deform and chip the screw heads. Any suggestions on removing these screws without destroying them? Thanks, PR.PR
Navarre, FL
1967 SIIa 109 SW
1979 SIII Lightweight (2010-12)Comment
I had this problem. i used a manual impact-hammer-gizmo (can't recall what its supposed to be called) with a slot head insert. inexpensive local hardware store device: align the driver in the screw slot, hit it with a hammer and it compresses and rotates anticlockwise about a 1/8th of a turn; repeat, repeat, as necessary. use a dab of anti-seize or grease on the threads when replacing.I'm in the same situation- trying to remove the brake drums. I have one flathead screw per drum, and they are stuck. My feeble attempts thus far to remove them with a wide screw driver have begun to deform and chip the screw heads. Any suggestions on removing these screws without destroying them? Thanks, PR.
This thing:
Andrew
'63 SIIA 88" SW
Rover Pics: http://www.flickr.com/photos/skunkal...7610584998247/Comment
Andrew beat me to it (although that one looks a little light-weight to me). Alternatively if you have access to an air supply a hammer drive will do the job. Good electric drills also have hammer drives but you need to set the speed low enough that it doesn't take off.
Good liberal application of penetrating oil first. If you use the impact driver in Andrew's post don't be shy with the hammer and use an engineering hammer (ball peen or similar) of sufficient weight (2-5lb). Carpentry or lighter hammers will tend to flake after some time and you don't want a shard of steel lodging itself in your eye.Comment
I have and have used the 'hand operated impact tool' that Andrew used and it works really well on the brake drum screws.Andrew beat me to it (although that one looks a little light-weight to me). Alternatively if you have access to an air supply a hammer drive will do the job. Good electric drills also have hammer drives but you need to set the speed low enough that it doesn't take off.
Good liberal application of penetrating oil first. If you use the impact driver in Andrew's post don't be shy with the hammer and use an engineering hammer (ball peen or similar) of sufficient weight (2-5lb). Carpentry or lighter hammers will tend to flake after some time and you don't want a shard of steel lodging itself in your eye.1958 107 SW - Sold to a better home
Lots of interesting questions and replies.
When the drum sits tight and flat against the flange rust builds up as we drive through water and other damp locations. This rust tends to glue the drum to the flange.
The little screws (mine have 2 screws/drum) are the factory's method of breaking the rust bond between the flange and drum, breaking the drum loose. They do not aid in fastening the drum to the hub. That is the job of the wheel and wheel nuts. THEREFORE there is no reason to tighten these little flat head screws down or if you have a better place to store them where you are sure never to loose them and they are always accessible, you can store them there. Personally, I slather the threads of these screws with anti seize and only screw them in enough so that the head does not sit proud. They always come out easily and are ready to use to break the rust seal and start the drum moving off.
If your drums are really rusted on you can squirt Liquid Wrench or equiv into the blind screw holes to help get things started. If they really don't want to slide off it can be helpful to adjust the snail cams all the way in to back the shoes away from the drums.
When I first got my truck back in '78 the screws were rusted tight into the drums. The impact screw drive was a wasted effort on my screws. After a night or two with liquid wrench, I got a left hand drill and drilled a hole into the middle of the screws and used an easy out.
I replaced all the old rusty screws with new plated ones and with the anti seize have never had a problem with the screws since.
The Land Rover factory service recommendations for Series trucks says:
- Remove brake drums and inspect for wear and leaks every 24,000 miles. and replace all the rubber in the hydraulic system with new kits every other time you do this, leaking or not.
If you actually drive your truck and put miles on it this is often enough to keep the drums from rusting too tightly to the flanges. If you don't drive your truck much it wouldn't hurt to remove the drums every could years and inspect the brakes anyway. It would keep the drums from sealing too tightly to the flange.
Since I'm off on a tangent. The factory service schedule is located in the owners manual for your truck. If you do not have an owners manual I have reproduced the serviced schedule on a web page:
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
Working from memory, here, but IIRC, on my SIII 109, the drums have an additional hole on the face that is tapped for the same thread as the 3 countersunk screws. Not sure if other drums have this feature.
One can thread a bolt into that hole so that it pushes outward against the hub flange, assisting one in removal of the drum.
Since there's only one threaded hole, I wouldn't recommend using it as the SOLE method of getting a drum off thats REALLY rusted tight, but rather as a constant outward force while you use all the other magic methods.--Mark
Had my drums off the other day to replace shoes and hub seals so I snapped this pic of the threaded hole in the drum that I was talking about and also the last-ditch method of removing the 3 countersunk screws using a drift and hammer.
Needless to say, I subscribe to the "slather anti-seize compound over everything" school of thought:
