Should I use a non-hardening (soft) gasket seal or a hardening? Thanks
Gear Box Oil Pan Gasket
sigpic
Nate B
88 D90 RHD, V8 Present
80 Merc 230GE Petrol in 2011
92 Range Rover - In the 90's
cuis2000@yahoo.comTags: None -
thankssigpic
Nate B
cuis2000@yahoo.comComment
You can use RTV gasket maker ( "The Right Stuff")that is what I used and it works the best because you can really get a lot on there. The gasket sets(proline) for the whole tranny is really cheap you can go that way too. Part Number PLC605 is the whole set of gaskets for the tranny ( not bad to have lying around)-Ethan
1966 2a 88' Pickup
1966 2a 109' Pickup
2002 F550 7.3l
1997 f250 7.3lComment
Partial Thread HiJack -
I used Permatex anaerobic gasket maker (red) on trans. Directions (which I ignored) mentioned using "Permatex Surface Prep" activator on one of the mating surfaces. I'm assuming this isn't vital. But thought I'd ask. I'm not taking it apart regardless. I'll wait for the inevitable leaks and then revisit.1970 88 IIAComment
