I am replacing the swivel balls on both sides of the front axle. The old ones were pitted / corroded all around preventing a good seal and killing the seals. Upon removal of the left Ball I found all of these pretty little roller bearing pins, as it turns out, from the u joint. That discovery put me in a lovely mood.
I know the shop book says to place the stub shaft on the horizontal and lightly tap on the stub shaft yoke. After removal of the retaining clip and some PB applied all around, tapping the yoke moved the bearing "cap" slightly downward (about 2 mm) but that is it.
Any suggestions for easier removal soz I kin remove the little bugger and put in a new u joint??
In reference to a previous thread ("worst series repair job")... THIS JOB IS THE WORST ONE IN MY OPINION. consider my vote cast.
