raiko bush for top swivel pin REMOVAL?
  • Cosmic88
    • Feb 2009
    • 78
    Also looking for the best / proper way to remove the bush for the pin on the top of the swivel ball??? It this a two piece assembly?
    I ask this because the ball itself has a recess and a lip on the inside portion of the ball and the taper of the bush sits on the outside... ?
    -Cosmo-
    '66 IIA 88" - Stock-ish Trail Rider
    '95 Disco R380 5 spd DD
    ARB winch bull bar
    Warn 8k
    Gulf States Grill
    OME HD 2" lift
    home made limb risers
    LR rack with too many Hellas
    on-and-on-and....
  • jac04
    • 1884
    I just did this job. I placed the swivel ball on wood blocks with the Railco bush facing down. I then used a long drift to reach through the center of the opposite bearing race and I drifted the bushing out with a hammer.
    • Cosmic88
      • Feb 2009
      • 78
      Either I need to jack up up daily intake of Wheaties! or it's stuck or I am missing something. I have been pounding on it to the point where I think it is overkill.
      I have soaked it in PB, made my own special little 'pounding base' from a 2x4 with a hole large enough to allow the bush to pass through with plenty of room and I beat on it like I would only treat a Jeep.
      This bush won't budge.... and yes I am passing the steel drift (1" dia.) through from one side to the other in order to "press" the bush out.
      -Cosmo-
      ARB winch bull bar
      Warn 8k
      Gulf States Grill
      OME HD 2" lift
      on-and-on-and....
      • jac04
        • 1884
        Wow, interesting. I was ready for a fight with mine, but they drifted out without any issues.
        I guess you could take it to a shop and have it pressed out - just make sure they don't damage the swivel ball.
        • daveb
          • 513
          PB won't do jack in this situation, the bushings are an interference fit i.e there is really no space between them for the PB penetrate into.
          I suggest you get yourself a MAPP torch and heat the area up a bit. Then try drifting it out. I've done this many times, it helps to jack the axle up and put it on a jackstand so you have a bit more room to swing your BFH. Which btw you should be using at least a 4-5 hammer...
          • Cosmic88
            • Feb 2009
            • 78
            going to go the heat / torch route this weekend. The ball is actually off so a full swing is not a problem and I am using a 5lb. shot filled (dead blow) hammer....I'm sure the heat will work... thanks for the input.
            I just didn't think it would be so stuck.
            -Cosmo-
            ARB winch bull bar
            Warn 8k
            Gulf States Grill
            OME HD 2" lift
            on-and-on-and....
