I am at a lose. bought the right fluid(last ?) and a hand vacuum pump. took Terry's advice and try starting at farest wheel from MC. rear wheels bled easy. got to passenger side cant get it to bleed. tried other front bled easy. checked bleeder screw not clogged found pin hole in line. replaced still cannt get any fluid out. even tried manual bleeding( pumping pedal) no drop in fluid at MC. so dont think theres a leak.
What should I check next.
the brake on the problem front seems to lock when testing at 5mph and 3 or 4 pumps. thanks for any input. in case it matters 65 ex-mod 109 rhd
