santana overdrive question
  • glbft1
    • 149
    I have a santana overdrive that works great but it hums when engaged is this normal for overdrives?
  • LaneRover
    • 1743
    Not being very bright, overdrives have to hum because they don't know the words. . .
    • Jeff Aronson
      Moderator
      • 569
      Overdrives, whether Fairey or Santana [Toro] make noise when they are engaged. For your comfort, check your overdrive case oil for amount and for the color of the oil. If it's not amber colored, I'd recommend changing it so you're running clean oil. It will help the gears and bearings last longer.
      Jeff
      Jeff Aronson
      Vinalhaven, ME 04863
      '66 Series II-A SW 88"
      '66 Series II-A HT 88"
      '80 Triumph TR-7 Spider
      '80 Triumph Spitfire
      '66 Corvair Monza Coupe
      • Firemanshort
        • 282
        If there bearing is worn - it will make a lot of noise. The gears will start to float a little if it is really worn and floating gears start to eat themsevles up. (Do not ask how I know.)
        If in doubt - new oil and new main bearing. The bearing is not that much are fairly easy to get to.
        Firemanshort
        1980 Stage One
        • Tim Smith
          • 1504
          I have also used Lucas oil as an additive. It was pretty amazing how much it quieted the transfer case and overdrive down. Now it only sounds like Armageddon is around the corner instead of right on my doorstep when I'm on the highway and pushing it in a speed run.
          I've heard Red-Line is good too.
