Any suggestions on removing the Spring Ring which holds third gear to the main shaft? This is so SIMPLE I can't believe I'm asking, but...
I've tried channel locks, an assortment of screwdrivers, and even alittle heat hoping to weaking the spring. It's surprisingly resilent.
My next step is going to be buying acouple of cheap screwdrivers, filing down the ends, and bending them to 90 degrees to try and lever that spring out.
There has got to be an easier way???
