I set out to bleed the brakes on my '64 109 SW, and of course I am now replacing the lines and wheel cylinders
. One of the front nipples snapped right off when I started to loosen it, whicih led to taking that wheel apart to get at the bad cylinder, which led to both the flex pipe and the cyl-to-cyl pipe being destroyed, etc. etc. I also had one rear cylinder nipple that I would have had to put the pipe extension on my wrench to get it to turn, so I gave it all up as a bad job.
I received the new Pro-Line cylinders and brake line kit from our hosts today. I have a couple questions before I get started on the refit:
1) Most of the lines appear to be steel with some sort of anodized finish on the outside. The wc-to-wc pipes for the front, and the long pipe running from the 5-way to the 3-way in the back are copper (I think). Anyway, is there something that it is worth spraying them with to help them last longer, or is it just not worth it?
2) I've read lots of places about the importance of double flare versus single flare on brake lines. I'm not sure what a double flare looks like in comparison, but these all seem to have just one flared lip at the ends. Since I got them from RN I trust they are the real deal, but would be interested in knowing the difference
3) The 5-way junction at the front is NLA. I don't know yet whether I'll be able to disassembe things and salvage the old one yet. In case I can't are there alternatives that can get used? Is this something I could get as a generic brake system part from the parts store?
. One of the front nipples snapped right off when I started to loosen it, whicih led to taking that wheel apart to get at the bad cylinder, which led to both the flex pipe and the cyl-to-cyl pipe being destroyed, etc. etc. I also had one rear cylinder nipple that I would have had to put the pipe extension on my wrench to get it to turn, so I gave it all up as a bad job.I received the new Pro-Line cylinders and brake line kit from our hosts today. I have a couple questions before I get started on the refit:
