best radiator coolant ????
  • Cosmic88
    • Feb 2009
    • 78
    Is there a particular, recommended type of coolant which should be used with the original (brass topped) radiators?
    -Cosmo-
    '66 IIA 88" - Stock-ish Trail Rider
    '95 Disco R380 5 spd DD
    ARB winch bull bar
    Warn 8k
    Gulf States Grill
    OME HD 2" lift
    home made limb risers
    LR rack with too many Hellas
    on-and-on-and....
  • gudjeon
    • 613
    I use regular Walmart variety universal anti freeze. I change mine every two years. Most stuff out there is made for multiple metal compatibility.
    You could spend more money of course and buy long life a/f. Good deionized/distilled water. 50/50 mix is the norm.
    • KevinNY
      • 484
      plain old green stuff in a 50/50 mix
      • Cosmic88
        • Feb 2009
        • 78
        ok
        That's pretty much what I thought but I figured it couldn't hurt to see if there was some double-secret formula conjured up by the mad scientists as Leyland.
        Thanks for the responses.
        -Cosmo-
        ARB winch bull bar
        Warn 8k
        Gulf States Grill
        OME HD 2" lift
        on-and-on-and....
