My daughter is getting married on Friday so needless to say it is more than a little hectic around here. I went to the store this morning to pick up needed items and on the way home my Rover refused to idle. I limped it home and started wondering where to start. This is simply no time to have my Rover not running correctly. I remembered reading several threads about poorly running Weber carbs. After doing a search and reading thru the sage advice I finally took the top off the carb and found that the bowl was full of junk. I cleaned the bowl and jets and put it back together. It still didn't run quite right so I used the rev it up and put your hand over the air intake. After a couple of times using that trick it came right out of it and now runs great. I couldn't have done it without the great advice for all of you. Thank you all very, very much.
Jim
Jim
