My '69 Ser. IIA recently had a new alternator installed. Prior to it being installed I never had any problems with the temp gauge showing anywhere near hot. After the installation of a new alternator it now run up near the red area of the temp gauge. I had the thermostat checked to make sure that it was not the problem and it checked out ok. Any suggestions about why it may be running hot now?
Overheating - New alternator
Blake McKinney
'69 Series IIA "88 SW LHD
'69 Series IIA "109 5 door SW RHD
'63 Series I Jaguar E-Type Roadster
'03 Mini Cooper STags: None -
Is the truck actually running hot or is it just indicating that it is hot? Does your fuel gage read correctly? Did you route the fan belt correctly? Did you, for some reason, remove the fan during this alternator swap? ---I know, the last two questions are kind of obvious, but there can't be many explanations for your problem.
Edit: Jim-ME types faster than me, but we're on the same track regarding the voltage stabilizer for the instruments.--Mark
New alternator - running hot
Thanks for the reply. I will have my Rover mechanic check out the various replies that were suggested as being a reason that the gauge would at least appear to indicate that the truck is running hot. I will post an answer once he has had a chance to review the possible causes and hopefully find an answer.
Thanks again,
BlakeBlake McKinney
'03 Mini Cooper SComment
