I was given a Smiths voltage gauge and I'm not sure how to wire it in. It has 2 terminals on the back, one with a yellow and black wire attached to it and one with no wires attached. FWIW the face has no numbers just a normal range with white either side of the normal slot. On the back there is one terminal with either the #1 or - stamped in the housing and the other terminal is marked #2. The first terminal #1 or - has a yellow and black wire attached while the #2 terminal has no wires attached. I would like to test it before I mount it. Any help would be appreciated.
Jim
PS
If this is is of any help there is a label with 073 on it.
Jim
PS
