I have a '78 Series III with an 2.25l diesel that had started giving me problems. It started smoking (white/blue) on start up but would clear up when it warmed up. I chalked it up to age and wasn't to worried.This was the norm for a few months. Then it started missing and a mile later it died. I was able to restart and limp home. It behaved like a clogged filter causing fuel starvation. Changed the filter which was long overdue and it ran fine. No smoke! Well 10 miles or so after the filter change it started missing and died again. Another limp home and I dropped the filter. The bowl was full of Black Diesel which was the case the first time but I thought it was because of overdue filter change. I drained the fuel tank but the diesel there was clean. The black settles out of the fuel and seems to be oil. I changed the fuel pump in case it had been pumping oil into fuel. Any thoughts of other ways oil could be getting into the fuel system. Could the injectors let oil through into the low pressure return?
Thanks for any Ideas, Dave
