Although the brakes still work in my SIII 88, I seem to have more pedal travel than before and the pedal does not return all the way when I let off. Both pedal return springs are present and springy. The truck doesn't pull or shudder under braking. It squeals as usual. I've check the fluid level in the MC and it's fine, hasn't dropped, is a little blackened, but fine otherwise. No leaks on the four corners. The plastic reservoir on the MC is deteriorating. The pedal is firm, not spongy.
I've got an idea of the pedal-no-return problem, any guesses from you guys?
Anyone have a rebuildable, dual line, servo brake master cylinder available for purchase? Must have a solid reservoir. (Hopefully solitation of items for sale won't warrant deletion of this post)
Many Thanks
Many Thanks
