stuck lug nuts - driving on a flat?
  • NickDawson
    • Apr 2009
    • 707
    If its not one thing its another... someone remind me that this is what I signed up for? Please omit the part where you told me that the English definition of "in good shape" is different than ours...
    Got a flat, it was low last night while fixing the carb, but now its totally gone.
    The lug nuts won't budge, I'm still rehabbing my blown knee, but I'm no slouch either...those puppies aren't moving. They are also somewhat stripped out. I let some WD-40 soak in for a while and got one lose, but the rest are beyond me.
    If I drive it 3 city blocks to the service station on a flat, is that going to ruin my wheel? I've been considering some 235x85 BFG A/T (or equivalent - based on suggestions that I've yet to solicit) ... After the transfer case and carb, I hate to buy my way out of this challenge, but I could chalk it up to two birds with one stone.
    Anyway, I'd hesitate to drive even that short distance on the alloy wheels on my BMW, but these things look pretty strong. They are the stock 16(.5?) wheels.
    On a related note, I've learned that a hi-lift jack is entirely impractical for lifting the back tires... from the side and you ruin the sills, from the back and you have to chock the front wheels
  • I Leak Oil
    • 1796
    Why not just fill the tire with air and drive it down? Don't drive on the flat unless you want to replace the tire also.
    • NickDawson
      • Apr 2009
      • 707
      No compressor, but I do have a hand pump - good idea.
      I'm not opposed to replacing them now, was going to do it soon anyway
      The treads are ok but they are a bit cracked - dry rot?
      • VTRover
        • 340
        Use a can of fix-a-flat or slime and you should be good to go. Three blocks I would not worry about driving it if that's your only choice. Check your insurance and see if you have free towing....... yada, yada. I'm sure you will figure it out.
        • NickDawson
          • Apr 2009
          • 707
          all very good points - I do have towing...
          thanks gang
          • thixon
            • 909
            Nick,
            Use another car to go to Home Depot/Lowes/Menards/Ace/whatever is near you. Buy yourself an electric impact wrench.
            The lug nuts will come right off, and you'll be needing a tool like that sooner or later anyway. I use my electric more than I use my air impact.
            I'm not going to lecture on using impact sockets with it. Its your choice. Some people do, some don't. Do you like to live dangerously?
            Good luck, and don't worry, they have to come off sooner or later.
            One last piece of advice. When you get frustrated with it, step away and rest. Its supposed to fun, not a hassle.
            Travis
            '66 IIa 88
            • TJR
              • 279
              IMHO.. A Hi-Lift jack is a great tool with dozens or uses, but not the one I would ever choose to use for changing tires unless it was a complete emergency.
              A floor or bottle jack (even on a board ) under the axle backed up w/ jack stands is MUCH more stable and therefore MUCH safer. With a high lift you have to unload the suspension & tire sidewall compression to lift a tire which causes a higher raised load
              Hi-lifts have their place, but can be easily knock over with the high load point (high center gravity) and narrow footprint, so tugging on tires or lug nuts could make it shift out of position.
              Obvioulsy you should loosen the lugs nuts while the tire is firmly on the ground.
              ..Talbot
              • Tim Smith
                • 1504
                You could try putting a standard car jack under the tire iron to add torque to the lug nut and then with your third had, take a hammer and wrap on the lug nut end of the tire iron to try and break it free. Kind of a poor mans impact wrench.
                • NickDawson
                  • Apr 2009
                  • 707
                  Thanks guys
                  I'm torn between beating this problem on my own and just biting the bullet and buying the tires I was going to buy in a few weeks anyway.
                  Of course, I'm also due for a new compressor and an air impact wrench does sound fun...
                  If I go the new tire route (and thus make the lugs someone elses problem) - 238x85xr16 seems to be the prevailing thought..I think thats about a 32...sound right?
                  • 4flattires
                    • Aug 2007
                    • 424
                    Class !!!!!
                    ....have we forgotten the time-honored tradition of a cheater bar? Even a 5th grader weighing 65lbs can tug on a 6 foot chunk-o-pipe and bust some nuts.
                    Jeff
                    64 SIIa 109 all stock
                    69 SIIa 88 all stock
                    Old tractors
                    New Harleys
                    Old trucks
                    • bmohan55
                      • Sep 2008
                      • 435
                      I recently got 235-85-16 mud tires and they look quite right, and perform well on & off road. Also switching from bias ply to radials made a HUGE difference the ride!
                      '72 S3 88 - Leakey & Squeaky
                      • NickDawson
                        • Apr 2009
                        • 707
                        shopping the tires now - thanks bmohan55
                        My III has parabolics (the english equivilent, not sure how robust they really are) - can I get away with a 33" Like a 255x85xr16?
                        • bmohan55
                          • Sep 2008
                          • 435
                          You may have to adjust your steering stops...if they are not stuck! I had to adjust mine when I went from 15" to 16", one broke off so I have some rubbing on hard left hand turns until I address that problem. But I like the narrow looking tire better for the Series, JMHO. A wider tire would also decrease your turning radius...and remember you have no power steering!
                          • ScottT
                            • Jul 2008
                            • 96
                            Exactly what i was going to say. I have a 6 ft piece of pipe in the shed for that purpose alone. When my air impact wouldn't budge the lugs a breaker bar and pipe made easy work of it.
                            Jeff
                            • NickDawson
                              • Apr 2009
                              • 707
                              I actually tried that - the nuts are borderline stripped so the wrench slips off more often than not. Once I get them off, I think its time to replace 'em
