my question is what is the proper way to wire the Ammeter (within the fuel, ammeter, high beam cluster) to show both alternator output current (when the engine is running) and draw against the battery (when the engine is off). First of all, I am fixing P/O wiring, so keep that in mind. The P/O had the alternator output wire leading up to a fuse block, not to the battery as one would expect. I have corrected this which led to having to rerun most connections for lights and such.
Second detail to keep in mind, I have the original positive earth harness on this truck with no voltage regulator. No need for a regulator as the alternator has an internal regulator. I have a "one wire" alternator with the output post connected to the batt. there are two additional wires from the alt... one is the exciter wire which I have jumped from the output post... a sort of self-exciting circuit and the other wire leads to the charge warning light in the dash.
In the original wiring diagram the ammeter calls for three input wires... one from the starter switch circuit, another from the inspection socket and the other from the voltage regulator.
Best way to wire this sucka???
Thanks all...
Thanks all...
