So I'm trying to get my timing nailed down. With it being early IIa/ex-MoD I have no pointer on the pulley, just the flywheel marks.
I've spun my flywheel using the starting handle and the only marks that I have come across are "EP" with a couple of lines across from it. This must be pretty close as my rotor is pointing to the #1 wire on the cap and the truck does run, so my timing isn't very far offf.
*Has anyone else seen these marks on their flywheel? And if so, how close are they to the actual TDC timing marks from the EP? With my luck lately, I'm betting the marks I need are on that rusty spot of flywheel I keep turning near.
Thanks all!
Thanks all!
