Brake Question
  • amcordo
    • Jun 2009
    • 740
    Brake Question
    OK,
    Noob question:
    1. How do I tell if my brakes are already dual, and
    2. why is that more desirable than single?
    Thanks!
  • LaneRover
    • 1743
    If there is a big brake booster in between the top of the brake pedal tower and the brake master cylinder then you have dual brakes.
    dual is better because if you blow a seal or get any sort of leak with a single line system you automatically lose all of your brakes. With a dual system you lose some braking power but do not lose ALL of your brakes.
    Brent
      Not necessarily. I have power-assisted brakes with a single circuit master cylinder on my 109.
      A better way would be to count the number of brake lines (metal tubes going toward the brakes) coming out of your master cylinder. If there is one line, you have a single-circuit master cylinder. If there are 2 lines...well, you can figure out what that means...
      • LaneRover
        • 1743
        Rovers are kind of like the English language - no rules that apply every single time!
