Lucas 45D Distributor O-Ring
  • jac04
    • 1884
    Just in case anyone else has run into this issue:
    The Lucas 45D distributor is sealed with an o-ring where it enters the engine. I contacted our hosts, who couldn't find a listing on the o-ring and told me that the cork seal would work (which it doesn't). A standard 2-021 o-ring seems to fit, but the cross-section is .070" and doesn't provide enough compression to seal properly. I ended up purchasing a pack of 50 Buna-N o-rings in the correct metric size (M2 x 23.5, .079" cross-section) to fit the 45D distributor.
    If anyone needs an o-ring and would like to make a small donation, pm me. I have a few to spare.
  • 83lee
    • May 2008
    • 36
    I had the same trouble with my Lucas 25D distributor.
    RN sold me the cork gasket, but it does not fit. Looks like an O-ring should go into the groove at the top of the distributor shaft housing (where it plugs into the triangular piece).
    Anybody know the real story on this?
    • jac04
      • 1884
      There is definitely supposed to be an o-ring in that groove. The 25D and 45D should use the same o-ring.
      Check out:
        I wonder if Bostonian1976 (Jason) would be interested, since oil squirts out of his distributor shaft hole and gets all over his engine bay? Perhaps this (non-listed) missing o-ring was his problem all along...
        • 83lee
          • May 2008
          • 36
          Sure enough, your diagram shows the o-ring.
          The round cork ring (RN part #52278) does seem to drop into the hole in the triangle housing. I wonder if both the rubber and the cork together are how it was designed to be?
          • jac04
            • 1884
            ^ No, because the distributor that uses the cork seal has a recess for the cork seal to sit in. The 45D doesn't have this recess, so the dist will sit too high if the cork seal is installed.
            • alaskantinbender
              • Dec 2012
              • 53
              Reviving an old post. Does anyone have a part number or listing for the proper O ring? I cant seem to find it with the info already posted.
              Thankyou
              1963 Series 11A 109, Left hand drive, Koneg PTO winch, ACR 2.8L 5 bearing power plus Engine with weber carb. Truetrac gear driven limited-slip traction rear differential.
              • roverp480
                • Jul 2020
                • 334
                Try 513682A https://usa.minisport.com/513682a-di...er-o-ring.html
                • alaskantinbender
                  • Dec 2012
                  • 53
                  Thank you. Now I need to find it locally in the USA so I don't need to sell a kidney for shipping.
