So I noticed my shifter would not shift into gear the other day. I checked the fluid and sure enough it was empty. I was thinking maybe it hadn't been checked in a long time. So I filled it up, bled out the air bubbles. It shifted fine for a few days...then I noticed it did it again. This time, I discovered there was fluid leaking from the flywheel housing at the bottom drain. Now I've never noticed before (as I was just under the car bleeding out the air bubbles a few days ago...I would have noticed it dripping on me) but is there suppose to be a plug in there preventing the loss of fluid? This doesn't seem right as the manual only says the plug should be in only if doing hard off-roading...including water and mud. My guess is that somethign has gone bad internally but I'm not familiar with it enough to diagnose the problem. Everything is leaking so bad on the rover that I'm guessing some kind of seal or slave cylinder has gone bad. Can anyone point me to whats going on?
Please note: I have the tranny and transfer case from a D90 (LT77 & LT230). Engine is 2.5L Milspec.
