The clutch is almost gone in my 64 2A. It has the 2.25 petrol motor, 4 speed tranny and fairly overdrive unit. What parts am I going to need to get this clutch replaced? Thanks for any help!!
64 2A clutch help!!
Here's what you should need for your little project:
Clutch disc
Pressure plate
Clutch alignment tool
Pilot Bushing (in flywheel)
Bolt lockers (for flywheel to crankshaft bolts)
The last 2 items you don't really need unless you plan on having the flywheel resurfaced. -
Thanks for the info!! I saw a lot of different pieces and wasn't sure what I need and what was just accessories.
1964 Series 2A 2.25l petrol, 4spd, Fairly ODComment
dremmel with cutting discs. it took me longer to pull out the floor, tranny cover and seat box than it did to pull the tranny. most of my bolts had to be cut, drilled or ground off'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
