Military Shackles
  • Jim-ME
    • 1379
    Military Shackles
    For an 88 running parabolic springs would I have problems using military shackles in the front only? I've got 3 leaf rears with a soft top and would like to level out the height front to rear.
    Jim
    Jim, I had to do a couple things with the same front setup as you're asking about. I had to notch the engine cross member because the drive shaft would hit it when the front end drooped. I also had to add 2 degrees worth of shim to correct the caster angle as the steering became a little heavy for my taste. The shim also helped with the pinion angle.
    • Jim-ME
      • 1379
      Thanks Jason.
      Jim
      • jac04
        • 1884
        Jim- Which parabolics are you using? I had Rocky Mtns on my 63 soft top, and had to run front military shackles to level it out.
        • graniterover
          • 167
          Jim,
          You've seen my truck a few times. I too have mil length shackles in front. It's great with the soft top or a pickup top, but with the hard top and a rack on, the normal shackles are probably best. At least on my truck. Glad to hear others have done this - I really thought it was a hack but nothing seemed right - as soon as I put the longer shackles on it was (and is) great.
          Mark
          • junkyddog11
            • 195
            Jim,
            Im running the military (or my version of that, which are actually a little longer) on my heap. Didn't have to cut the crossmenber for the driveshaft, just used an old D90 shaft. GBR also makes a skinny one to solve this issue. Did have to shim the axle 4 deg to get the castor and pinion angle back.
            Matt Browne
            www.overlandengineering.com
            "resurecting junk through engineering"
              Yup, a smaller diameter drive shaft will accomplish the same thing. I didn't want to spend any money on a different shaft so I cut the front corner of the cross member and cut a piece of tubing diagonally and welded it in. More time but less money, same results.
